About Reflash Question~
aaron
Post by aaron »
Hi~
If I Reflash, How do I let the ECU reply the setting up value of former factory? :?:
Because I am afraid automobile pollution detection may be unable to pass. :(
If upgrade K-PRO and cruise the function is still here? :?:
Thanks! :wink:
I'm not really sure what the question is or what vehicle you are referring to.
aaron
Post by aaron »
I mean RSX TYPE-S ECU(37820-PRB-A14), If I allread Reflash Hondata (K20Z1), How I reply the former factory ECU setting up value.
So long as use the backed up IGNITION KEY (another that IGNITION KEY not sending Reflash) Can reply the former factory (ACURA) The establishment value of ECU?
Say I should have another former factory (ACURA) ECU come to exchange?
If upgrade K-Pro,are cruising and SRS functions all also here?
Thinks!
The reflash will pass an emissions test.
To return it to stock costs $75. It will need to be sent here.
SRS is not affected by the reflash or K-Pro.
Cruise control with the K-Pro may not work as well above 75 mph.
aaron
Post by aaron »
If I have another 2006 RSX-S ECU, and send this ECU ,IGNITION KEY and Immobilizer to HONDATA reflash.
Pass in time a bit, I gain the ECU of former factory, have any influence on the IGNITION KEY and Immobilizer?
You will have to have the key and immobilizer matched to the new ecu. It is recommended that you just send your stock ecu that is already matched to the key and immobilizer.
aaron
Post by aaron »
So REFLASH, do the change of the computer procedure, it is not to change with the procedure in the IGNITION KEY and Immobilizer, is it like this?
If so, my another one ECU 、IGNITION KEY and Immobilizer, post HONDATA REFLASH, after this ECU REFLASH, be identical with IGNITION KEY and Immobilizer?Make the car mobilize.
My idea is to leave the former factory ECU, then another one ECU of REFLASH, but does not change under the situation of the IGNITION KEY and Immobilizer, while letting me in fact gain ECU afterwards, the car can mobilize.
