purchased s300, quick question
BabyBhp
Post by BabyBhp »
Hi
Ive just purchased a S300 not realising theres one specificly for the JDM ecu's.
I have two ecu's one is from a sir b16a and the other is from a jdm civic D15B (PO8) i think.
Is there anything i can do, to make it fit any of my ecus?
If not will its be better of using a uk spec ecu?
Also just to make sure, im OBD1 which means i wont need a harness of anything?
Thanks for your time
Yasir
The s300 will only fit in a rectangular USDM or UKDM case. THe s300j will only fit in a JDM case.
An OBD1 car will not need an adpater harness.
BabyBhp
Post by BabyBhp »
Thanks for your help m8 8)
