Gm map sensor not working
BlueTurboteg
Post by BlueTurboteg »
I put a gm 3 bar map sensor the way it shows on the website, i know its wired in right,now when i load it on the hondata the car will not start...im using MOTEC 3BAR,, and i try with the stock map sensor plugged in stilll. and without it plugged.. i need to read that extra boost, anyone know something bout this problem??,thanks guys
Be aware that if you incorrectly wire the MAP, even for a split second, it will be fried. Check the reading with the MAP plugged in and the engine off - it should be around 100 KPa, depending where you live. If not, check the parameters in SManager.
BlueTurboteg
i checked the wireing.. its fine am i supposed to have the stock one plugged in?? and am i just not programming it right??
THe stock sensor should not still be connected. Have you tried starting the car with the stock sensor after changing the wiring?
BlueTurboteg
yes the sensor was plugged in, i thought you were supposed to have them both pluugged in,so thats how i tryed it...I ddint mess up the ecu did i?>
kaj
Post by kaj »
BlueTurboteg wrote:yes the sensor was plugged in, i thought you were supposed to have them both pluugged in,so thats how i tryed it...I ddint mess up the ecu did i?>
your ecu can not process the signal from two MAP sensors at the same time. as long as the sensor was wired right, you should be fine. sending mixed signals to the ecu should not have fried it, i think.. but i've never tried. :P
so. did the car run when you hooked up the stock MAP sensor only?
Wolli
Post by Wolli »
I was looking at my map measurement, and i do not have the 100 kpa. I had ignition on, car not running and 0 kpa. I changed to stock map sensor, and there i had also 0. But my car runs great. What is the reason for this??
Is your pressure setting relative or absolute? 100 kPa absolute = 0 kPa relative
Wolli
Post by Wolli »
It makes no difference, to what i set it. I have 0 kpa in every case. I had vacuum unit and pressure unit set different, and also tried psi, bar and kpa. But when the engine?s running, i have normal tables!? I just hope, they are normal ;-). Do you have an idea? I don?t live on the Mt. Everest!!
bdcivc
Post by bdcivc »
Did you change the settings on the s 300 from your stock sensor to the 3 bar map sensor setting? And did you use the right setting? Using the wrong sensor on a stock setting would cause the car not to start!!
BabyBhp
Post by BabyBhp »
Is motec 3bar setting ok for gm 3bar?
There are at least 3 different GM sensors. This is why we only recommend the Motec sensor.
