injector/ecu possible problem
spdracr70
Post by spdracr70 »
ok so i recieved my rc injectors the other day and just figured they where the right ones so i installed them well the car wouldnt start, i later realized the injectors where wrong and sent them back and recieved the saturated ones, install them car still wont start, this is the first time starting this built motor, is there a way to make sure the ecu is ok since i read about possible damgage with wrong injectors, i mean nothing changed how the car was trying to start with either injector so maybe i have the timing off a tooth or something
thanks
brian
First you must determine what the problem is. Do you if the injectors are firing and is there spark as well?
spdracr70
Post by spdracr70 »
yes there is spark, fuel etc, just seems flooded
You have either damaged the ecu, or you have messed up the wiring, or both.
YOu will have to oduble and triple check the wiring of the injectors.
