mikeedge
Posts: 14 Joined: Tue Aug 15, 2006 11:47 am
Post
by mikeedge » Tue Aug 15, 2006 11:49 am
I am currently tuned on Hondata S200. I am looking into installing my push button so I can control my rev limit, launch control, and shift light.
I have read on the Hondata installation guide that once installed... the rpm points are initially set to the following...
Launch Limiter: 3000rpm
Cam Change point: 4800rpm
Shift limiter: 6000rpm
Shift light: 7800rpm
Now my question is... my vtec crossover is set right now to 4400rpms. Once I install this, is it going to switch it to 4800rpm? and am I going to have to reset it back to 4400rpm?
Thanks for any help.
Posts: 24359 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Tue Aug 15, 2006 11:53 am
If VTEC has been set in the ecu it cannot be adjusted via the interface box.
mikeedge
Post
by mikeedge » Tue Aug 15, 2006 12:21 pm
Okay, so I don't have to worry about my crossover going to 4,800rpm?
mikeedge
Post
by mikeedge » Tue Aug 15, 2006 12:59 pm
Okay, I plugged the push button in and set my launch control rpms to 2,500 statically. I turn my car on and press the clutch in and when I step on the gas pedal, the launch control doesnt work, my rpms just rocket.
Any ideas why?
Post
by Spunkster » Tue Aug 15, 2006 3:44 pm
Datalog and make sure that the ecu is seeing the clutch switch engaging and disengaging.
mikeedge
Post
by mikeedge » Tue Aug 15, 2006 5:09 pm
Lol, I found out that I need the clutch switch. I was under the impression that I only needed the clutch switch for Full throttle shift.
Where should I get the clutch switch from? I have access to pepboys, advance autoparts, etc.
What are they called exactly?
mikeedge
Post
by mikeedge » Tue Aug 15, 2006 6:45 pm
Okay, I went out to pepboys and bought a switch. Now my question is, How do I go about hooking it up to the Hondata?? It didn't come with any wires or anything.
mikeedge
Post
by mikeedge » Wed Aug 16, 2006 1:43 pm
Lol, I looked through that manual so many times. It just does not say how to hooke up the clutch switch to the hondata.
I am fully aware of where to put the clutch switch, but just not how to hook it to the hondata.
Post
by Spunkster » Wed Aug 16, 2006 3:22 pm
It plugs in on the interface box where it says "Clutch Switch"
mikeedge
Post
by mikeedge » Wed Aug 16, 2006 4:35 pm
Lol, I am aware of that. But I do not have any wires that plug into that. The clutch switch I bought came with just a clutch switch. Here are some pics of it...
Post
by Spunkster » Wed Aug 16, 2006 4:50 pm
Every s200 is shipped with the necessary cable to connect to the switch.
mikeedge
Post
by mikeedge » Wed Aug 16, 2006 5:29 pm
Hmm, well I bought this from a member off Team-Integra so that could explain why I do not have the cable. I did have th push button tho.
How could I acquire one of these cables?!
Ps. Thanks a lot for all your help! I appreciate it.
Post
by Spunkster » Thu Aug 17, 2006 9:15 am
You can purchase a replacement through any Hondata dealer.
mikeedge
Post
by mikeedge » Thu Aug 17, 2006 10:14 am
Okay, is it just the cable? or the clutch switch as well?
