S200 Problem
Jester
S200 Problem
Post by Jester »
hey all,
My car seems to have reset itself. and everything is running crap. kind of a "safe Mode". when trying to connect with Hondalogger it says, "This system does not have datalogging enabled" does anyone know what is causing this or better still...how to fix it?
Is the light on the interface box flashing or solid? Are you using the Romulator or burning chips?
Jester
Post by Jester »
the interface box is flashing and it happened burning chips.
any ideas?
It could be a socketing issue, problem with the chip or a problem with your interface cable...You will have to use process of elimination and use a multimeter to check continuity of the wires and traces on the ecu.
Jester
Post by Jester »
we found the problem. its the actual chip. when the power was disconnected it must have wiped the chip.
would it be possible to get a Base ROM for a civic B16a2? we have an image for a b16 but if that falls through we were gonna just put it back to a base ROM. if you could possibly send me a base rom for a b16 civic that would be great.
cheers,
William.
We don't make or send out base maps, but you can contact your dealer and get one through them.
Jester
Post by Jester »
cool, thank you for your help.
