question about the s300
civicext
Post by civicext »
whats going on?
just to make this quick. i have a s200 witch i am about to switch it over to the s300. the program or files i have for my s200 be transford to an s300 nad also dos the s300 come with a base probrame?
thanks
You can download the Smanager software and see the calibrations built in to it and also see how it works.
From the Smanager help file:
Upgrading V3 Files
RomEditor V3 files may be opened from the File menu. These files are automatically converted into s300 compatible files. There are a number of differences to note from the conversion:
? V3 ROMs do not store the old and new injection size in the file. When converting you are prompted for this information.
? Launch limiter rpm and shift limiter rpm are now stored in the ROM file.
? Features used in the SManager software will be initialized to default values.
sulsa76
Post by sulsa76 »
I'm not flaming you, but you should spend a moment spell checking your post. It makes it difficult to respond when we aren't sure what you are asking.
94 Integra LS with NA GSR block/head
Endyne pistions, 14 pound flywheel, Civic SI crank pulley, honed gsr intake manifold, 70mm BBK TB, Stock GSR cams, stock exhaust/header
