Does my temp correction really need to be -40 deg
smracing
Post by smracing »
Can I raise the lower columns above -33 degrees? The software won't accept anything higher than -1 in the last two columns. I live in Alabama, there is no way short of some ecological disaster that I will ever have to start my car when it is -40 degrees out side.
How does the software recognize the accelerator pump function? I assume it is based on a rate of voltage change. Is there anyway to modify this algorithim?
The temperature numbers must be consecutive, and the software will not let you enter a number which is higher than the number to its right. If you want the lowest number to be higher you need to raise the temperature numbers from the right to the left.
The TPS fuel is calculated from rpm, load, water temperature and rate of throttle opening, You can change the volume of fuel with the 'Throttle Tip In Trim'.
