Greddy turbo
jbs06si
Greddy turbo
Post by jbs06si »
Since i have already done the reflash can i also do the turbo and if so do i have to send my ecu back to you for any reason????
JBofMD
06civicsi
Post by 06civicsi »
i was also wondering the same thing.i have the reflash aswell and im about to install the greddy turbo kit.
i know that the advancing of the cam angle is what will make us lose power with a turbo.but how much did yall advance the timing?is it enough advancing to cause hp and tq loss?
We do not offer any reflashes for Turbo appliations for the 06-07 SI. With a Turbo you will need to return your ecu to stock.
06civicsi
Post by 06civicsi »
Spunkster wrote:We do not offer any reflashes for Turbo appliations for the 06-07 SI. With a Turbo you will need to return your ecu to stock.
but what if we already have the reflash and get the greddy turbo kit and run the e-management will the reflash have any effect on the way the turbo runs i.e. loss power if so about how much?,gain power.is it safe to run the reflash and greddy kit with e-management?
i know the probl. comes in with the advancing of the cam angle.in the thread i started asking the same question i was told by hondata that the cam angle was not altered much.was it just altered at the v-tec cross-over? or throughout the entire power band?
To use the emanage you will have to return the ecu to stock. The reflash was designed for NA.
jbs06si
Post by jbs06si »
why do i have to return to the stock ecu if i go with the e-manage ? what will it hurt or what are the problems with piggy-backing the re-flash?
JBofMD
With the reflash there is too much ignition for forced induction.
jbs06si
Post by jbs06si »
OK, thank you for the info....any idea when or if you are going to come out with kpro for the 06 Si? I'm having a lot of problems with completing my turbo. I have the e-management ultimate but no harness for it except the hard wire one it came with and i DO NOT want to hard wire it. Any help will be great...
JBofMD
06civicsi
Post by 06civicsi »
jbs06si wrote:OK, thank you for the info....any idea when or if you are going to come out with kpro for the 06 Si? I'm having a lot of problems with completing my turbo. I have the e-management ultimate but no harness for it except the hard wire one it came with and i DO NOT want to hard wire it. Any help will be great...
you can order the pnp wire harnest from greddy.
jbs06si
Post by jbs06si »
they dont have it, its been on back order for over 4 months and they are not sure when TRUST is going to make it or ship it.
JBofMD
06civicsi
Post by 06civicsi »
jbs06si wrote:they dont have it, its been on back order for over 4 months and they are not sure when TRUST is going to make it or ship it.
try to check again.they just got a shipment in yesterday.
