suggestion: memory for data adjustment?
kaj
Post by kaj »
is there anyway to make an adjustment to the program so that when i make an adjustment to a set of cells it will stay highlighted?
after data logging for a longer period of time, i'll start making adjustments. as i work down the log, i come across cells that i THINK i've adjusted already.
i've resorted to writing down the rpm/vacuum/boost cells i've made adjustments in to be sure i don't mess with them again, later in the log.
or.. is there a way to do this already?
There is no way to do this. You will need to just keep track of your changes and either note them in the notes, or in the file name you save the file with.
kaj
Post by kaj »
i figured. no prob. thanks!
sure would be cool, though!
