S200 with boost, but boost not selected ...
vactor
Post by vactor »
i have an S200 (with a base JRSC ITR chip) installed on my ITR with JRSC. i bought it with Boost and datalogging. well, i did a very quick datalog after the install just while the car was idleing. i used the datalogger and the ecu information in honbdalogger. it has all 3 options not installed (boost, datalogging and 3 step rev). the "ecu information" tab says the ecu serial number is S200-xxxx and when i select "upgrade" the dialog box appears with the serial number of the same, is this a bug? datalogging works fine (even though when i start datalogger while connected to the interface box i get the "datalogging has not been installed" error, but the car starts right up and i have no problems datalogging. I do still have yet to drive it and see if i get errors under boost. should i not worry about it or is this something i should call you guys about?
S200 JRSC ITR.
Doodoo
Post by Doodoo »
Remove J12 and the ECU Info should show up after you do that.
vactor
Post by vactor »
oops. forgot to add that the ecu is the OBDII connectorized P28 from hondata, so J12 was removed by them (i checked to make sure).
S200 JRSC ITR.
Boost / datalogging
Call us and re-enter the unlock codes.
vactor
Post by vactor »
thanks Doug. turns out that i was using the "ECU Settings" incorrectly, attmepting to get the settings AFTER i had already "connected". everything's just peachy. thanks for getting back to me!!
S200 JRSC ITR.
ECU Settings
Not Doug, but you're welcome.
