launch control setting question
Posted: Mon Aug 28, 2006 7:17 pm
by B16T
my question is Basicly i want my turbo to spool alittle quicker off the line right now i have it set so my activation rpm is 100less rpms from the launch Limiter rpm, If i put them the same would it bounce alot quicker, cause right now theres a delay between the bounces, or is it my stock map sensor thats giving me the short delay, hard to explain but i hope you undersatnd what im talking about
Posted: Mon Aug 28, 2006 7:19 pm
by B16T
Or is that the way the hondata 2step is only reason im asking becuase my buddies 2step on the AEM it bounces really hard, and i dont know if its casue the stock map is slow or thats the way the hondata is Thanks
Posted: Tue Aug 29, 2006 9:14 am
What RPM are you trying to set your launch control to?
Posted: Tue Aug 29, 2006 4:13 pm
by B16T
ive got the launch limiter at 7200 and the activation at 7100
Posted: Thu Aug 31, 2006 9:32 am
by B16T
So i guess thats just the way the launch controlis on hondata, to build more boost ill have to retard timing alittle more or turn up the 2step?
Posted: Thu Aug 31, 2006 10:02 am
You will have to experiment with what settings work best if you are trying to use the launch control as antilag. Keep in mind that this is also very hard on the turbo.
Posted: Thu Aug 31, 2006 11:21 am
by B16T
Thanks, will there be anitlag added sometime int here near future?
Posted: Thu Aug 31, 2006 11:47 am
It's alerady there. It's part of the launch control settings.
Posted: Thu Aug 31, 2006 11:53 am
by B16T
ohhh hahaha thats the ignition retard, and fuel enrichment?
Posted: Sun Sep 02, 2007 11:27 am
by Boosted91
hate to bring back a old thread but dam i read so many search results and they all ended like this, not 1 clear answer from the mods here. do the mods here even know how to explain to set up the antilag? i posted a thread asking exactly this earlier today and am waiting to find out just this. i mean telling some one to play with settings in no way explains what each setting does. what does adding fuel do or taking it way do for antilag? the same for the timing?
Posted: Mon Sep 03, 2007 11:13 am
by GTMcoupe
google is your friend, if you want to know how anti lag works look it up as there is more than one way to do it, with the hondata you basically retard the ignition so that the fuel is still burning when you open the exhaust valve hence very high egts and turbo life surfers, settings will depend on what cam timing, turbo, exhaust etc etc, hence you will have to experiment to find what suits your set up.
WEST
Posted: Tue Sep 04, 2007 10:44 am
Boosted91 wrote:hate to bring back a old thread but dam i read so many search results and they all ended like this, not 1 clear answer from the mods here. do the mods here even know how to explain to set up the antilag? i posted a thread asking exactly this earlier today and am waiting to find out just this. i mean telling some one to play with settings in no way explains what each setting does. what does adding fuel do or taking it way do for antilag? the same for the timing?
What works for one person may not work well for another. There is no setting that is universal. You will just have to experiment and see what works best for your engine.
