Can a P75 ECU use D6 VTP as a clutch switch??
TurboLS
Post by TurboLS »
I'm just wondering if all boards are equipped with the interconnections to do this even though the functionality is only in VTEC ECU's. If I can, that would be cool because I wouldn't have to sacrifice any of the other inputs.
TurboLS from Team-Integra.net
(703)919-2786 (C)
Yes the circuitry for vtec presure is inside all ecus.
TurboLS
Post by TurboLS »
sweet, thanks man.
(703)919-2786 (C)
TurboLS
Post by TurboLS »
OK, now I have another question. I checked my ECU and it doesn't have the "D" connector, only A, B, and C. Does that mean I have to wire directly to the board instead of the harness?? I would really like to use the D6 function instead of brake switch or the others because I actually use all of the others. thanks for the input.
(703)919-2786 (C)
You have a D connector. The ECU does not have a C connector - it goes A, B, D.
TurboLS
Post by TurboLS »
hmm, ok, apparently i have some f'ed up pinout diagrams then. thanks for the info dude. i was really worried for a second there.
(703)919-2786 (C)
