Different rev limiter if stuck in low cam on Euro R H22A?
Vexamus
Post by Vexamus »
Hey all, I'm still working out the bugs in my Euro R H22A with a P30 and s100.
I got the base program for the Euro R and it runs great. I still have to get a VTEC oil pressure switch so vtec will work, or if you could tell me how to bypass it so that it won't throw a code 22.
Here's my question
I'm stuck in lowcam, but I still make great power even up high, but theres a rev limiter at 6500, what's up with this? I had my dealer set my rev limiter at 8200.
Disabling VTP
You need to get whoever supplier you with the base map to disable the VTP error in RomEditor.
Vexamus
Post by Vexamus »
Actually, I found a much easier fix than that.
Just clip D6 at the ecu, the VTP and splice it into the VSM(without breaking THAT circuit). or just run a jumper wire from D6 to A4 and it's fixed, no codes and vtec works perfectly.
