Feature request, Seperate 2D/3D maps and tables
smracing
Post by smracing »
Can the feature be added to separate the tables from the 2D/3D maps?
I would like to be able to close out the maps or reduce them or bring just the tables to the front so I can see all of the columns without reducing the maps or scrolling across.
QUICKSILVER RACING
Post by QUICKSILVER RACING »
It would also be nice to view the datalogged graphs with a view of the values like the one seen in MOTEC. Kinda hard switching back anf forth to display then graph.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
smracing
Post by smracing »
Good point. I forgot that. Would be nice to see the numbers and tables at the same time as the graphs.
Just re-arrange the windows so you can see them all at the same time.
GTMcoupe
Post by GTMcoupe »
While we are talking data logs etc, is ther an option or plan to have a max and min recal option on speed/lambda/rpm etc, would be a nice feature to have to see actually how far i over revved the engine on those missed shifts :roll: for example
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
smracing
Post by smracing »
Problem is when the car is running I want to be able to close the maps and see only the display and three bar tables. There is no reason to have the 2D/3D maps open when the car is running and datalogging.
I just want to seperate the maps from the tables so I can open, close, bring to the front, etc for each window.
