How to disable the EGR system in Smanager ?
mataos
Post by mataos »
Hi, I want to know how to disable the EGR system in Smanager (s300 with P72 ECU) I have been told there is an option somewhere but cant see it,
Unless you solder the components into the ECU, add a wire to A11 and enable boost control, there is no EGR.
mataos
Post by mataos »
Ok, so I can just remove the EGR valve (already blocked off) and EGR solenoid, block off the manifold vacuum pipe, and as the P72 wont support EGR I won’t get a code or any problems, is this right?
Correct.
mataos
Post by mataos »
Great, Thanks for your help!
