ITB Calibration
marck_c
ITB Calibration
Post by marck_c »
When will Hondata put out a base calibration for ITB's? Are you guys having the same problems getting it to work, as we all are??
Due out in the next week or so.
You cannot expect a TPS tuned engine to be as good as a MAP tuned plenum, however, the cars we have tuned on ITBs run quite well.
Your mileage may vary.
marck_c
Post by marck_c »
Have the cars you tuned ITBs on used MAP or TPS. I tried to setup the TPS on my car, but it won't even idle properly. When I switch to MAP it runs fine.
It's a road race car, so mileage is'nt very important.
On another note. I keep having my datalog freeze up ith ridiculously high rpms. I read all the threads, and checked the socketing, checked the grounds, and I still have this probelem, albeit intermittently. The display will work fine for 30 mins sometimes, other times it acts up continuosly. I can get it to resolve by unplugging and replugging the USB cable. But it's really annoying. Both the Red and Green LEDs are illuminated by the way.
Any ideas???
