s300 with aem 5 bar map sensor
Just use the default '5 Bar' setting. Switch the key on and check the MAP reading. It it is not atmospheric pressure, then check you wiring and/or MAP sensor. If you mis-wire a MAP sensor once, even briefly, it usually dies.
Silverbeast
Post by Silverbeast »
5 bars work fine as with the S300 :)
Use the settings that he said and it wll work.
BabyBhp
Post by BabyBhp »
What would be the correct way to wire this in?
WickedCivicNY
Post by WickedCivicNY »
wire it like you would a GM 3 Bar .. Signal/Power/ground
