Will I encounter problems running the 05 tranny in my DC2K
bossman032
Post by bossman032 »
I wanted to run a newer tranny. Since my current one is messed up..
will I encounter problems with the speedo meter and other things??
I have a tsx motor.. :roll:
Swap everything from the 05 transmission into the 02-04 case. You may need to press on the speed sensor gear drive onto the 05 final. Otherwise you are going to have problems with the speed sensor and/or wiring.
bossman032
Hondata wrote:Swap everything from the 05 transmission into the 02-04 case. You may need to press on the speed sensor gear drive onto the 05 final. Otherwise you are going to have problems with the speed sensor and/or wiring.
are u guys working on a fix without having to swap everything out from the 05 to 04 case??
No, there is no easy fix.
