aftermarket cams for 06 si comp. w/ reflash?
06civicsi
Post by 06civicsi »
i was woundering if there are any aftermarket cams that are comp.with the reflash for the 06 si?
also i heard that the tsx cams would be the best.is this true?
This is not something which we have tested. Because the Si uses an AFM the fuel tables would be largely self correcting for cams, however the VTC timing would not be optimal.
06civicsi
Post by 06civicsi »
so if i would us the toda high pwer cams spec b and the vtc killer cam gears would that take care of the vtc timing probl.?and the afm would adjust to the new cams?
No. The VTC Killer cams gears will not work with a stock ECU.
06civicsi
Post by 06civicsi »
is hondata going to test any cams with the 06 si? pref. toda would be the best to test with! to see if any would work with the reflash?
It is up to the cam manufacturer to drive any reflash development for their products.
legendman
Post by legendman »
Hondata wrote:It is up to the cam manufacturer to drive any reflash development for their products.
I heard you guys were working with IPS, any details you could give us.
This post contains hearsay (Automatically inserted as per forum rule #6)
06civicsi
Post by 06civicsi »
i know they are working with toda.
I heard they were bought by the Japanese...
