New car, no hondata knowledge
racefan11
Post by racefan11 »
Alrighty, the problem i am having is that i am running to rich. My wideband is showing 10.5 while its about 60 degrees out side when i am in the throttle hard. I know i can add some timing, but how do i do this through hondata? Any examples would be great. Also, any other suggestions on how to get it to lean out some? I am getting it tuned soon, but i need something NOW.
1216 ITR
scottishpol
Post by scottishpol »
You need to remove fuel... from the fuel tables, not add timing!
racefan11
Post by racefan11 »
Ok i took 3% out of my overall fuel trim and its running a lot better. ANy other way of goin about this?
1216 ITR
racefan11
Post by racefan11 »
OK, when i adjust fuel tables, do i just need to select one section, or the whole table, and decrease selection?
Right now i am pretty good after 5krpm im at 12.9-13.7 but before then its still low, around 11.0-11.5
1216 ITR
First you should read the help files. Go to Help and click on Contents. THis will help you understand the basics of tuning and how the software works.
