kiced off datalog under boost
moses187
Post by moses187 »
02 rsx-s
greddy turbo/intercooled
650 injectors
k-pro with tuned map
new usb cord with ferritts
correct ground position and a grounding system.
ive tried to datalog with several computers and several usb cords.datalogging is fine until i hit boost(b/w 3200-3800rpm)it just shuts off.i can stop boosting turn datalogging back on and it does the same thing again.a/f ratio looks good until this point.i dont know what to try next.ive searched and i have not seen this exact problem.i have had trouble before with my daughter board,sent it to you guys and you fixed it.any help would be great.thanks
kris lester.
Did you use the greddy spark plugs? They are non-resistor and will damage the ECU.
