ecu questions
T66crx
ecu questions
Post by T66crx »
i ordered this ecu from this guy and it is a P06 converted to a P28 but i was matching it to a frineds P28 and their are some things that was not takin out of the P06. does this matter if they are in or should i get them takin out
Depends on if everything is working correctly or not. And it all depends on what exactly you are referring to.
T66crx
Post by T66crx »
these are the ones that were not takin out of my P06 and that the p28 does not have. D12, D13, Q34, R135, C61, C63, Q103, R6, D1, D4, R8, R9, C7, Q2, R90, C71, J5. now these are the ones that are not in my P06 and are in the p28 C52, C51.
Sorry, but Hondata does not do Vtec conversions on P06 ecus. You willl just have to try it and see if it works properly.
Jaker
Post by Jaker »
Several of those parts, on preliminary inspection, are for the automatic side of the ECU, which are disabled when you convert the ECU to manual. Some of the others are not familiar to me.
The C51 and C52 are capacitors that Honda (OEM) and others install when enabling the socket for external memory (chipping). Long ago, it was decided by some that those capacitors were not really required to permit successful activation of the socket, so they are for the most part left out.
T66crx
Post by T66crx »
thanks
