Hey Guys, Need help in adjusting Nitrous w/ K-Pro
Craig_Ellis
Post by Craig_Ellis »
Well, I have everything hooked up now to K-Pro. (had the dealer hook up my wires to the ECU).
I am using a 50 shot and the default nitrous fields when selecting "enable nitrous". I am using a base map (stock engine w/ 440cc injectors) with the K-Pro.
The map was adding 200 fuel units and retard'ing the engine 4 degrees. (i dont know if this is good or not). I went to use the car with the nitrous and the engine started to backfire, and ran like crap. It was starting to run so bad, that I got out and took the fuse out of my nitrous relay and re-uploaded the base map without the nitrous enabled.
Thanks guys,
Craig
You need to tune this properly on the dyno to avoid damaging your engine.
