rpm stop on 3700
toprpm
rpm stop on 3700
Post by toprpm »
This the first time I run the s300j in my car and I have a problem .
the rpm stop on 3700 .
Any body can help my I will be thanx.
Who socketed the ECU? Can you datalog? Do you have a check engine light? Are there any error codes?
toprpm
Post by toprpm »
My Friend socket it.
Yes I can datalog.
Yes I have check engine light.
Yes there are 4 error codes.
OK, what are the error codes? With a JDM ECU you must disable the atmospheric pressure sensor, fuel injector error check and VTEC pressure, so I'm guessing they are the first three codes.
toprpm
Post by toprpm »
I soketed again and now every thing is ok but I have Two problems :
1- I have check engine light.
2- Error in oxgyen sensor .
