2step and FTS questions
T66crx
Post by T66crx »
what wires go where to hook up the 2step and FTS. im tryin to use the clutch switch.
It all depends on how you are setting it up. You need to run the wire from the switch to the input on the ecu that you select in the software.
T66crx
Post by T66crx »
i put a switch where cruise conrotol would be. i know one wire goes to the ecu and where does the other one conect too. and the FTS hooks up to that same switch right
one wire goes to ground, the other goes to the ecu
blbvtec
Post by blbvtec »
is it ok to use the existing cruise control switch and just add another wire run over to the ecu? no relays or anythign involved?
thanks
YEs you can use the existing switch, but there is no need for relays as all you are doing is grounding the input.
blbvtec
Post by blbvtec »
thanks
InJ3cted
Post by InJ3cted »
I cant seem to build a lot of boost (maybe 2-3psi) I've tried different settings with the fuel enrich and ign retard but same thing. The only way I can get it to build boost is if I pre-load
I also noticed that the revs are far apart, is there any way to shorten the revs? It doesnt crackle or pop like I hear with other 2steps or antilag setups... maybe I'm lacking MSD or other things?
thanks
Denny
What RPM do you have it set to?
InJ3cted
Post by InJ3cted »
5-6k i've tried more or less same result?
