ECU for my engine
Dubs13
ECU for my engine
Post by Dubs13 »
I have a ZC DOHC engine in my 95 Civic HB with an OBD1 setup. What would be the best ECU for my car? Thanks.
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100, s200 or s300 depending on what options you want.
