Code 1 O2 sensor error lights up while open loop
see2k
Post by see2k »
Well this has happend to me once but its happening to my friend alot.
On occasion his check engine light pops up with the CEL Code 1 Primary O2 sensor. I find this hard to believe when his car is running in open loop and therefore his O2 sensors are not functioning, or the readings are being ignored.
To humour the error we did replace the O2 sensor, but found that not to be the problem? Could this be an ECU issue? Its a p72, and my p28 also did that code once, but never came up again after I shut down and restarted the car.
We're going to check whether the rom needs updating, however, if that is not the problem, what else could it be?
I attend college at U-Si-R... Wanna start a club there?
210whp 155 wtq S200@5.5psi@7200 rpm
230whp 177 wtq S200@~9psi@7200 rpm
rebuilt engine 9:5.1 compression
271whp 236wtq S200@14.5psi@7200 rpm
1/4 Unknown
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Yup. I talked to matt about it already. They are fixin it. But it not performance related so no issues there except for the annoying CEL.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
Code 1
This was fixed in RomEditor V3.2.2 It only occured once after a cold start.
see2k
Re: Code 1
Post by see2k »
Hondata wrote:This was fixed in RomEditor V3.2.2 It only occured once after a cold start.
welp it still does it.. im running romeditor 3.2.2.4 and the o2 primary sensor pops up. It usually pops up after about 50+ miles of driving and or 40 minutes.
Its consistent as to when it just pops up.. And no its not the shift light :wink:
the only other thing I can think of is that the p72 ecu is bad, or going bad, and just throwing this code out there? or there is obviously a flaw still somewhere running around. This has happened once with a p28 ecu running 3.2.2.2. After a long drive of 50+ minutes, the cel 1 pops up while I was cooling down the motor.
It hasn't happend to me ever again. but it happens to my friend consistently who i've updated his rom to 3.2.2.4
gosh i need to find my CD and reload the old version of romeditor, something like 3.1.x.x
1/4 Unknown
JT
Post by JT »
The same thing happened to me twice today during street tuning for approx. 10 miles. The engine is fully warmed up (water temp @ 190F). I'm using V3.22 and P28.
blkcrx
im using a p28 using 3.4 and get it too..
Post by blkcrx »
Well yeah i get this error all the time....also with a p28 and version 3.4 it seems to occur when I?m off throttle a fair bit ie city driving in traffic.. driving without driving hard. but it only happens after 20min+ of driving.
Regards James
AndyE
Post by AndyE »
Another data point to add...I get this CEL with the v3.4 ROM under open loop operation as well.
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
