When using AC, idle does not kick up like stock
oscarmayer
Post by oscarmayer »
on a stock honda, when I have the ac running, the idle is kicked up higher than when it's not on. how come with the S300 this is not working? Is there a setting I'm missing?
Got Boost?
OscarMayer
oscarmayer
is there a reason the admins have chosen to ignore this issue?
Got Boost?
OscarMayer
You have not given enough information to disagnose the problem. See http://www.hondata.net/forum/viewtopic.php?t=3772
For a start:
- the calibration
- a datalog of the AC cycling on and off
- any other pertainent information
jkdjoefzr
Post by jkdjoefzr »
I've been running the s300 in my 95 Integra GSR since May 06, and neither the "stockitr","usdmp72",or "jdmp72" would kick up the idle w/ a/c on. My car kept stalling w/ air on. I eventually just raised base idle from 750 to 900 to compensate....just thought it was the software. I don't have any datalogs either. Is there a way to fix it?
there are still no datalogs or calibrations posted
