s300 datalogging problem
jbcivic03
Post by jbcivic03 »
I just got a s300 install on to a p72. The local shop was trying to tune it but wont datalog at all. It prevously had the older hondata systems. Does anybody know what may be causing this?
Follow this guide: http://www.hondata.net/forum/viewtopic.php?t=5226
If you can upload but not datalog then it is the socketing.
jbcivic03
Post by jbcivic03 »
seems to be the socketing what can i do to fix it?
Check all the soldering and make sure all the components are in place. I would suggest sending the ecu to us and paying to have it resocketed.
http://www.hondata.com/ecusocketinginfoform.html
jbcivic03
Post by jbcivic03 »
I had it install at redline perfomance in arlington tx. They are one of your dealers. Do you think they will be able to fix it. If i send it to you would you be able to test it before you send it back and how long will the repair take?
Your first step should be to contact the dealer.
uglyasscivic1
Post by uglyasscivic1 »
Check that J12 is removed.
jbcivic03
Post by jbcivic03 »
If i send it how long would be before i get it back if its over night delivery? O and uglyasscivic1 what is j12?
Turn around time, if the ecu can be repaired is 1-2 days.
jbcivic03
Post by jbcivic03 »
Whats is the address that i should send it to?
What did your dealer say?
The address at www.hondata.com :
Hondata, Inc.
386 Beech Ave
Unit B2
Torrance, CA 90501
You must also include the socketing from at http://www.hondata.com/ecusocketinginfoform.html
and include the cashier's check or money order.
