Repair of S300
marck_c
Repair of S300
Post by marck_c »
Does Hondata offer repair of their units? I have an S300 that is damaged due to incorrect impedenance injectors being used in the ECU. The ECU got damaged as well. The distributer sparks even when the car is off!!. The engine won'nt start and it is impossible to communicate with the S300. Various ECU's were swapped around, and by process of elimination the S300 and orginal ECU are found to be damaged.
Can Hondata repair the S300J if it is returned to them, and do they offer socketing as a service as well?
You can send it in for evaluation, but it is unlikely that either the ecu or s300 can be repaired.
If you send it in, be aware tha you will need to include a very detailed description of the problem. If any repairs can be made, you will be charged a minimum of $75.
The ECU socketing form can be found at http://www.hondata.com/ecusocketinginfoform.html
