Help! IAT question
MugenSi99
Help! IAT question
Post by MugenSi99 »
hey everyone!! I'm going to be turbo'ing my car soon.... I have hondata s300 installed and everything.. I drive a 99 civic Si with the stock b16a2... well I have a dumb question...
Where does the Intake Air Temp. sensor go when I install the turbo?
does it go to the turbo inlet tube after the filter? or on the charge pipes?
I have asked many ppl and nobody knows... could anyone help me out?? Thanks in advance!!
Jess Conklin 99 Civic Si
Soon to be boosted...
It should be as close to the intake ports as possible...the intake manifold, the runners or lastly the charge pipe.
MugenSi99
Post by MugenSi99 »
thanks!! you just helped me out GREATLY!! I wasn't sure if the boost would affect it or not... but I have been reading where iat temps are measured, so I didn't think it went on the turbo inlet tube... Thanks again for the info!
deafy
Post by deafy »
My prelude came stock with an IAT sensor and its located on the intake manifold, opposite side from the throttle. Maybe that'll help??
MugenSi99
Post by MugenSi99 »
mabye I'm thinking of the wrong thing :? where does the sensor that is on the intake tube go? this is one of the VERY few if not the last thing I am unsure about...
Jaker
Post by Jaker »
Starting in 1996, Honda moved the IAT sensor on the Civics (Integras too, I think) from the intake manifold to the intake tube between the airbox and the throttle body. If you are using Hondata S300 (or any other form of Hondata OBD1 engine management) the ECU is expecting the IAT to be in the vicinity of the OEM OBD1 location (intake manifold). Its not that the ECU will kick a code if its in the wrong spot, but the air temperature correction parameters built into the ECU software are configured for that location.
It'll just work better if the IAT is in the intake manifold. If its not there, move it. If there's no holes, make some.
locash
Post by locash »
FYI - All 94-2001 Integras have the IAT sensor in the Intake Manifold.
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
MugenSi99
Post by MugenSi99 »
thanks jaker!! this helped alot... I was confused between people saying it was already on there and stuff... I greatly appreciate your response!! hopefully this thread will help other people out!
