05 Type-S Reflash and 370cc injectors?
drumnatural
Post by drumnatural »
U state that RH and Reflash runs lean.
What would be the effects of adding 370cc injectors to a CAI, RH, Reflash combo?
Also would there be any negative effects while running in closed loop mode?
The reflash is made for stock injectors. You cannot use 370cc injectors.
