LAUNCH CONTROL
dfruit
LAUNCH CONTROL
Post by dfruit »
WHAT ARE SOME GOOD SETTINGS FOR A B18B TURBO 10PSI FOR THE FUEL AND IGNITION SETTINGS
There is no correct answer. Depends on the car, driver and the combination of parts. You will have to find what works best for you by trial and error.
Marlon88
Post by Marlon88 »
Sorry for hijacking your thread but since we are speaking about lounch control I have a qusestion please. I made a switch in my dash to activate the lounch control , can you please tell me wich pin from the ECU I have to connect the switch to ? My car still has the A/C system so I can`t use that system. Also what current do I have to input the ECU ,negative or 12+ postive?
Marlon
B16T
Post by B16T »
yea goodluck, I dotn think sits possible without slipping the clutch from my experince, teh revs are too slow i wish they can add a better antilag tot eh S300 Then it would be Perfect :D
airshifter
Post by airshifter »
the launch control would build 12 to 15 psi on our b16 with a t4/t66, now with ls/vtec it makes almost 20
