s300 datalogring freez and error codes problems... help...
sohctuned
Post by sohctuned »
i juss bought s300 and had it dynoed and tuned. bout 2 weeks ago. and last weekend i was goin to change my launch control to higher rpm, after i turn on the car and started datalogging, it froze on me after 1 min or so and error codes shows up. o sensor 1 and 2, ignition, injectors, etc... no check enjine light... car is driving normal and sarts... the light inside the ecu is a steady green and red...
the problem again is after 1 min of datalogging, the data logging window freez and error codes showz up, the light inside the ecu is green and red, steady lit... please help....
Has J12 been cut and who socketed the ecu?
sohctuned
Post by sohctuned »
i dunno what a j12 is... and if you know the shop called modacar in livermore... i forgot his name his white guy thoe...
You should take it back to your dealer and have them check the socketing.
sohctuned
Post by sohctuned »
ok thanx
