Honda Type-r speed signal
dex
Post by dex »
I have a 2002 Honda Type-r rally car I have instlled LSD in the transmission, but because of this I no longer heve a speed signall, can I solve this with Hondata. can Hondata operate without speed signal?
What is the chassis code, what sort of engine do you have and what is the ECU code?
dex
Post by dex »
Its an EP3 Type r. I will collect the rest of the data you need.
Thanks.
dex
Post by dex »
Chasis no.: SHHEP33501U000274
Engine no.: K20A21000225
I do not know my ECU code.
Is this info enouhg for you to answer my question?
Check the ECU has a 37820-PRA part number.
You can run a constant 80 kph speed signal in the KPro. The only issue is that the reverse lock out has to be disabled.
As long as you do not care that you will not have a correct speedo reading on the dash, then you can use the K-Pro and set a constant speed signal within the ecu.
dex
Post by dex »
I dont care,i dont need speed reading, its a race car. what about ABS if I take out my ABS, will it couse a problem?
The ECU doesn't care about ABS.
