couple questions about hondata = boost + nitrous
dafuzzbudd
Post by dafuzzbudd »
ive read through the hondata.com site
1.) it isnt clear where you get a boost solenoid/ where is it installed
2.) what are these "compontents" that need to be added to the ecu
3.) so a high boost button can be done? http://hondata.net/forum/viewtopic.php? ... t+control"
4.) with nitrous control, ecu will manage injecters eliminating the need for a wet system, right?
5.) does aem wideband have a compatability problem? and does the plug have to be modified?
thanks to anyone for even a partial answer
QUICKSILVER RACING
Post by QUICKSILVER RACING »
1. http://www.hondata.com/images/boostcontrol-diagram.gif
2. Detailed instructions for component installtion is in the software help file.
3. Yes.
4. Yes.
5. Don't understand your question
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
dafuzzbudd
thank you for answers and the diagram is very helpful.
the boost solenoid, im taking it these are not honda specific.
what's a good make to get?
http://cgi.ebay.com/ebaymotors/maserati ... enameZWDVW
aem seems to be the most popular wideband. while searching wether it was compatable with hondata i found people with some problems. does the reading output on the aem plug directly into hondata. i read you have to adjust the voltage reading. other than that should it work fine or should i go with a different brand?
under important notes in smanager help:
Do not exceed the stock MAP sensor's pressure range (approx 10.5 lbs).
does these mean dont use over 10.5lbs of boost?
The solenoid is a GM solenoid, the part number is listed in the help file. We recommend using teh PLX wideband ( www.plxdevices.com ). THat warnign about the map sensor is becuase the stock map sensor cna only read to about 10 psi. You will need to get a 3 or 5 bar map sensor to boost above that level.
dafuzzbudd
i found the part number for it
but where can i actually order/buy it?
1997152
Contact any Hondata dealer.
