k-pro?
jbs06si
k-pro?
Post by jbs06si »
im looking to do the Greddy turbo and i see you post about k-pro...Sorry i dont know what k-pro is.....and how would it work,help???.....thanks for the help
JBofMD
jbs06si
Post by jbs06si »
thank you for the help.....
JBofMD
jbs06si
Post by jbs06si »
so if i do the k-pro is there anything i need to after that? Just plug and play or is there a program i have to deal with to make things run as they should.If so do i have to take it to a shop or can i do it?
JBofMD
jbs06si
Post by jbs06si »
sorry i also have one more question to ad on the last post: If i do the k-pro can i still piggyback the Greedy's e-management from there kit?. I already have the ecu re-flash from you guy's
JBofMD
The KPro is a plug in module to a stock ECU. Therefore anything to the stock ECU you can also do to a stock ECU with KPro, including piggybacks. However, there is zero point in using a piggyback once you have KPro.
06civicsi
Post by 06civicsi »
jbs06si what car do you plan on using the k-pro for?if for the 06 civic si,there is no k-pro for it.
jbs06si
Post by jbs06si »
06civicsi,yes its an 06 si.............thanks
JBofMD
