5-Bar Map Sensor with S300
WickedCivicNY
Post by WickedCivicNY »
Has anyone on here successfully gotten their car to run with a 5-bar Map sensor with 1600cc's, I've tried everything from .. Adjusting the injector multiplier lower, Decreasing the low-fuel values etc .. and nothing seems to get the car to start.. Wiring has been triple checked.. swapped sensors and no luck ..
Tried the stock Map sensor and works fine .. Just won't work with the 5 Bar Setting that is in the parameters tab.
Hondata - Any suggestions you'd like to give in regards to getting the 5-Bar to work correctly ?
If the car runs with the stock MAP and doesn't run with 5 bar then it must be either the settings, wiring or MAP sensor.
What pressure do you see with the when you switch the ignition on and datalog? It should be atmospheric pressure.
Are you unplugging the stock sensor?
