s300 into a 90 CRX d16a6 ,ECU swap
S. Rothschild
Post by S. Rothschild »
i have my 90 CRX with a d16a6 SI motor and i all so have your s300 p28 with the jumper, wide band bla bla bla ...... ok will this even work for this application? please help :?
I think i'm going to have a BEER now .......
It might if you can find an OBD1 distributor that properly fits and is phased correctly. However this is not something Hondata supports.
S. Rothschild
It works
Ok I got it to work; distributor needed for this swap is a td41u or 92 to 95 civic non vtech for the 1.5. Wiring ......use the OBD0 to OBD1 jumper and make a jumper from the stock distributor plugs to the OBD1 distributor. You may need to reverse the polarity on some of the censers, or I could have just jacked it up but the ecu swap does work.
If you are wondering why some one in there rite mind would even want to do an ecu swap like this. There are new rules for 2007 season of the Honda challenge H4 class witch allows now the OBD conversion of this type. All for the coveted 2-3 more ponies.
