S300 Boost Control
JITU
S300 Boost Control
Post by JITU »
I am running JDM B16A 2nd gen Engine with JDM OBD1 P30 ECM, I am planning to go for Hondata S300J for Boost, with a new feature of Boost control from the ecu which can be used only on USDM ECU since JDM ECU does not have circuitry to modify for boost control, can i use a USDM P28 ECU with Hondata S300 & Boost control option to run on an JDM Engine? will it work ? I want to compare P28 US & P30 JDM Codes for refrence.
any clues ? I want to use boost by gear feature on S300 with boost control.
Thanks in advance
Jitu
QUICKSILVER RACING
Post by QUICKSILVER RACING »
should be no problem.
just load your tuned calibration to your new ECU.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
If you load the calibration into a US or JDM ECUs they will run the same. We have noticed a slight difference in the idle control circuitry, but the fuel, ignition etc will be the same.
