logging stops/connection lost
civiccoupe
Post by civiccoupe »
tried to tune my s300 but every time i try full throttle run at about 5000-6000
rpm logging stops and the ecu disconnect from the laptop.
have changed laptop,ecu,everything.
any ideas?
thank you
Do you have on-board datalogging enabled?
civiccoupe
datalog
no i dont have enabled it.
i try to log with my laptop.
GTMcoupe
Post by GTMcoupe »
Had a simular problem myself, whats your battery voltage when the logging stops you can checkthe log, as i had issues with a voltage drop in my kit car stopping me from datalogging when ever i tried at night due to having the lights on and VTEC engaging.
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
Also make sure you have resistor type spark plugs.
civiccoupe
spark
Spunkster wrote:Also make sure you have resistor type spark plugs.
plugs are:ngk bkr7en11
civiccoupe
GTMcoupe wrote:Had a simular problem myself, whats your battery voltage when the logging stops you can checkthe log, as i had issues with a voltage drop in my kit car stopping me from datalogging when ever i tried at night due to having the lights on and VTEC engaging.
WEST
will look it
thank you
civiccoupe
batt
WEST
will look it
thank you
batt voltage was 14,2v
Check your ground on the thermostat housing. Clean it and make sure it is good and tight.
civiccoupe
checked
Spunkster wrote:Check your ground on the thermostat housing. Clean it and make sure it is good and tight.
i have checked it but nothing happen:(
What type of ignition system are you using?
civiccoupe
ign
Spunkster wrote:What type of ignition system are you using?
msd digital sci
msd wires
msd coil
GTMcoupe
Re: batt
Post by GTMcoupe »
civiccoupe wrote:.......................batt voltage was 14,2v
Not that then
Mine was dipping down to just below 11v thats when i had problems
WEST
It is most likely your ignition system. Try returning it to stock including wires.
civiccoupe
ign
Spunkster wrote:It is most likely your ignition system. Try returning it to stock including wires.
will try it.
thank you
