Any chance Hondata will have more RPM and load points??
TurboLS
Post by TurboLS »
Basically, I am designing a custom valvetrain and I need to have more quantization points for fuel and ignition values across the map. I know I can do this in load by using the boost tables and changing the values, but that's kind of using them for a different purpose, and only solves half the problem. If you could shed any light on this, that would be awesome.
TurboLS from Team-Integra.net
(703)919-2786 (C)
If this is an LS, then set up VTEC and use the high and low cam tables.
TurboLS
Post by TurboLS »
and i guess i would just wire a signal to the VTP switch when i want the maps to switch, correct?? Are there any other considerations I should be aware of???
(703)919-2786 (C)
Jaker
Post by Jaker »
Just disable the VTP error code, and set the Vtec point where you want the maps to switch. The ECU will never know the difference.
TurboLS
Post by TurboLS »
and by VTEC point, you mean RPM, correct?? thanks for the help.
(703)919-2786 (C)
Jaker
Post by Jaker »
Yes, RPM.
QUICKSILVER RACING
Post by QUICKSILVER RACING »
you can also add more load points by activating the secondary tables.
10 more columns for your tuning pleasure.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
