When car heated up it will not work
eikki
Post by eikki »
When car heated up he's gonna make ignition cuts or something.. i don't understand..
Can someone explain?
I put here a calibration and datalog also
When heating up all is super.
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Are you using a wideband o2 sensor? something wrong with your calibration. Even the datalog looks funny.
What engine combination are you using?
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
eikki
Post by eikki »
QUICKSILVER RACING wrote:Are you using a wideband o2 sensor? something wrong with your calibration. Even the datalog looks funny.
Yes I'm using wide band.
Engine is NA. Rocket cams 12.7cr aso. Until this morning all was fine.. In the morning i tried to make my idle smoother, but nothing.. I'm not touched the ignition or fuel map. until this kind of problems occurred
i tried with the old calib. also but no effort on that also.
The ECU internal power regulator is either dying or being overloaded by an external wiring short or a faulty sensor.
eikki
Post by eikki »
Hondata wrote:The ECU internal power regulator is either dying or being overloaded by an external wiring short or a faulty sensor.
Now i tried to upload a old basemap with Smanager V1.1.6 and everything works.. It's a miracle..
I don't get it really..
But what is ECU internal power regulator?
