Stock H22 with RC550cc
deafy
Post by deafy »
I tried the Stock H22 450cc calibration and its just not running right... its idling kinda rough and exhaust tone has completely changed... it sounds like my buddy's stage 2.5 WRX... would bigger injectors change the tone of the exhaust even though the AFR is normal? I know most of you are gonna say "get it dyno tuned" but I'm gonna wait till i have turbo installed first then get it tuned.
What injectors are you using?
deafy
Post by deafy »
i'm using rc550cc saturated injectors with no resistor box
deafy
Post by deafy »
Also, this is all open loop.
The calibration you are using was tuned with 440c injectors. You will need to get this car tuned on the dyno to get the correct A/F ratios.
deafy
Post by deafy »
I changed the fuel trim to 550cc and decreased the fuel map... afr fluctuates ALOT
Thats because it has not been tuned. Different sized injectors have different characteristics. You must tune this using a wideband at part and full throttle.
deafy
Post by deafy »
Found the problem... spark plug was wet, wouldn't ignite. Car runs BEAUTIFULLY smooth...
