there is a bug with 1.2.2.1
fvang
Post by fvang »
When you open a kal with ecutype=1 and right click on the load(map) values to try to change them, you get this error:
"floating point division by zero"
You can open up the civic stock kal to see the problem.
fvang
Thanks. Fixed for the next release.
menfou
Post by menfou »
A other problem since the first KManager and SManager Version.
In France we use , for the float and in US or England you use .
Sometimes when I save a Kal, all '.' become a ',' and mw .kal is a shit
You have a S300 calibration in attachment
Why you don't use ';' ??
The calibration file should always use . as the decimal seperator. Are you still finding a problem with the latest version of KManager?
menfou
Post by menfou »
I have the same problem with the last KManager version.
On SManager I have exactly the same problem
I have this problem when I datalog, modidy values, and save the calibration
Razathorn
Post by Razathorn »
Hondata wrote:The calibration file should always use . as the decimal seperator. Are you still finding a problem with the latest version of KManager?
I'm guessing that the function call you are making to format print / output floats to the config is doing locale specific things like using "," instead of "." based on where your code runs. Perhaps you could switch to a non locale sensitive output routine.
Wayne
menfou
Post by menfou »
Yes the problem it's French keyboard Vs US Keyboard.
I think the best solution is to use ; and not ,
Razathorn
Post by Razathorn »
menfou wrote:Yes the problem it's French keyboard Vs US Keyboard.
Doesn't sound like a keyboard issue to me.
