Fly by Wire Throttle control for the '07 CTR. K-Pro HELP.
mrdmferrett
Post by mrdmferrett »
Doug, the new CTR will have a fly by wire throttle control system. Is it possible that you can adapt your K-Pro to interface with the Map/Maf sensors and TPS so we can use this technology. Or sell a piggy back device that will enable removal of the TB (Idea for business).
The significant gain is reduction in parastic losses, reduction in heat soak and increase in throttle response because airflow is unobstructed.
You got any ideas?
Dan
Are you referring to the Euro CTR? If we do anything it will be a reflash (like we have for the US 06 Civic Si), as the KPro is for the 02-04 RSX/Civic ECU only.
As for removing the throttle body - are you sure you've thought your cunning plan all the way through?
