NLR Boost controller
B16T
Post by B16T »
Hello The NLR boost controller comes with a 5bar sensor is it compatible with the S300. Thanks Its comes with a SSI MAP?
Assuming you mean 'Can I use the NLR MAP sensor with the s300?', then yes, but not at the same time as the NLR boost controller. Your next question then probably will be 'What settings do I use in SManager?', and the answer is that you'll need the data sheet from the MAP sensor, then follow the procedure in the help file to calculate scalar and offset. If I've not answered your question correctly then try phrasing your post in the form of a question.
B16T
Post by B16T »
Thanks, But from what ive gathered the NLR uses its own Map sensor to control the gate and the S300 would use its own Map sensor... Thanks
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Let me break down what Hondata said.
You can use the NLR map sensor for HONDATA. You need two map sensors for the system you are trying to make.
EX. 2 NLR map sensors (1 for boost controller and 1 for S300)
1 NLR Map sensor(boost controller) and 1 MOTEC 5 bar map sensor(s300)
1 NLR Map sensor(boost controller) and 1 AEM 3 bar map sensor(s300)
If you only have one map sensor, then you can use the NLR map sensor but need to use the Hondata boost controller system.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
