Car not priming
1 si
Car not priming
Post by 1 si »
I have a k24a2 in a EP and I am using the ECU from the EP with the current V1.2.2.1. Car was running fine yesterday, but today after I uploaded a different calibration the car won't start. I was able to upload the calibration without a problem, but I noticed that everytime I put the key in the second position it sounded as if the car was priming; similar to when I upload a calibration. I tried to start the car, but it only cranks a few times and then it won't even do that and all of the lights will just flash with a ticking sound. I tried to use a different computer and couldn't even upload the calibration or get the priming sound as usual. Please help!
*Tried uploading several times; different cals.
*Cleared security
*Used different computer
Will check fuses and try kpro in a different car, any other suggestions?
Go back to a default calibration and try that to see if the car will start. Check that the immobilizer is disabled (if applicable), but in any case the engine should crank over and the dash lights stay on. If not, check that battery terminal connections and the engine grounds (including the strap from the transmission to subframe.
1 si
Post by 1 si »
will do thanks
1 si
a/f
Post by 1 si »
Ok, problem solved replaced battery.
