PRA euro ecu (nitrous)
Cosmic Charger
Post by Cosmic Charger »
Is nitrous control a function that can be used with this ecu.
If not, whats the best way of controlling nitrous, so that the map/fueling/ignition is altered to suit the amount of nitrous used?
Thanks in advance.
No, Nitrous controls will not work with a PRA, PRC or PRD. They do not have the circuitry to operate the outputs.
Cosmic Charger
Would it be best if i was to use a PRB ecu to control nitrous. Is the Kpro transferable from my PRA ecu to a PRB one????
Could i use my AEM wideband with the 0-5v output with the PRB or would i still have to install another wideband and do the wiring mods?
YEs, a PRB would be best. You cannot use the aem wideband with the PRB. You will have to use the OEM wideband sensor
